Gel Battery? Best Battery for a bike parked at an airport?
Posted on Σεπτέμβριος 4, 2017 by BBR-David
Posted on Σεπτέμβριος 4, 2017 by BBR-David (Member Score: 9002)
Hi there,
For ease of travel, I have a bike stored outside at an airport and I use it about every 2 months.
At the moment the bike has a traditional standard lead/acid battery in it.
As the battery is not new, I figure it is only a matter of time before it becomes sulfated and and can no longer be used.
I was therefore considering a GEL battery as a replacement and I am wondering if these would last longer under such conditions?
Thanks for any tips.
David
Posted on Σεπτέμβριος 5, 2017 by BBR-David (Member Score: 9002)
Looking into this some more, it seems that a gel battery is actually just another type of lead acid battery so I don't think it will be any less prone to becoming sulfated up.
I'll keep looking round for another alternative.
Posted on Φεβρουάριος 4, 2018 by ReDaLeRt (Member Score: 0)
Just disconnect the negative terminal of the battery. Then, you can also replace it with a lithium one because has a lesser self discharge rate.
Posted on Φεβρουάριος 5, 2018 by BBR-David (Member Score: 9002)
That's handy, I hadn't thought of disconnecting the negative terminal to slow the rate of discharge, nice tip. thanks.
i decided against a Lithium Ion battery in the end, as I understand that once they are completely discharged they can no longer be recharged again (that and the price :))
Many Thanks
David
Posted on Μάρτιος 10, 2019 by dexterbeef (Member Score: 67)
If the bike is stored outside and in a secure location, then one of the cheap little PV panels hooked to the battery will keep the battery in good fettle. I use one on a couple of bikes for longer term storage where I did not have a mains supply. It worked!
Posted on Μάρτιος 10, 2019 by BBR-David (Member Score: 9002)
That's very handy to know.
Thanks for the useful suggestion
David
Posted on Οκτώβριος 22, 2019 by anth01 (Member Score: 0)
I've never had that problem with the battery not been able to be charged once flat. and a solar panel is the way to go I've two and they work fine even in low light conditions
